Interface between Unitronics PLC's and panels directly to computer network and software tools
Feb-1st, 2018 8:47
There are several options to interface between UniStream  PLC's and panels directly to computer network and software tools.
  • Modbus Communication.
     UniStream support both Modbus TCP/IP and Modbus RTU serial –RS232 and RS485-.
     For this the SCADA or other equipment should support Modbus drivers.  UniStream does not support OPC server.
  • As mention on previous email, the latest version of UniLogic and BIN supports SQL with Microsoft SQL and MySQL.
  • SNMP V1/V2c/V3 communication.
  • The UniStream can be configure as FTP client and/or server. This will let you exchange files between the PLC and the PC.
  • Use the option "message composer" and protocol blocks to build the message you receive and on the computer then create a program that will link this message with your application.
You can find examples of each of this communication  by downloading them from UniLogic help menu>Download examples and in the same menu you'll have a link to our YouTube channel for video tutorial on some of this subjects.
4 out of 9 found this helpful
