UniStream Adapter Ethernet/IP EDS Template for Omron
Apr-21st, 2019 6:29
Attached is a template EDS file for UniStream as Ethernet/IP adapter.
The adapter addressing were defined as captured below:
These data you have to put also of course in Network Configuration of Omron Ethernet IP settings:
As well as the Input/Output size in bytes:
Based on the size of the array that you set in UniLogic:
And of course the same size of bytes has to be set in Omron Network configuration settings:
This Template EDS was create by one of our great partners that implemented Ethernet/IP communication between Omron as Scanner and UniStream as an adapter.
3 out of 3 found this helpful
