Filter installation and dimensions in Inverter
Feb-18th, 2019 7:30
C3 filter installation on an Inverter
1.Remove the Inverter front  cover and fix the C3 filter on the cover with screws.
2. Connect the C3 filter cables (L,N,Gnd) or (R,S,T,Gnd) in parallel to the Inverter's Input cables and ground.
3. Mount back the Inverter's front panel with the attached C3 filter.
C3 Filter Sizing
W1
W2
W3
H
D
81mm
80mm
69.4mm
32.5mm
32mm
W1
W2
W3
H
D
69.8mm
67mm
58.4mm
31mm
38.5mm
