• Help Center
  • Submit ticket
  • Login
  • Unitronics website
    • English
    • Russian
    • English
    • Russian
  1. Home
  2. Help Center
  3. Unitronics VFDs
  4. Connecting multiple motors to a single VFD
  1. Home
  2. Help Center
  3. Unitronics VFDs
AA
Mar-27th, 2019 12:48
Connecting multiple motors to a single Unitronics VFD is possible with some conditions.
1. Operating speed should be the same
2. Failure point must be set for all motor's as one point(If one motor fails all motors must be stopped as well)
3. VFD power size must be sum of all motors power.
2 out of 3 found this helpful
 Unitronics VFDs
  • VisiLogic and VFD
  • UMI (Unitronics VFD) Regenerative
  • UMI (Unitronics VFD) Heat Dissipation
  • Cable length between VFD and motor
  • VFD - Configuring 2 frequency sources
  • UMI Braking Resistor Calculation
  • VFD Keypad Password
  • VFD - Stop VFD when communication lost with PLC
  • Unitronics VFD Quick Start Guide
  • Unitronics Motion Inverter cable gauge and required Torque for Terminals
  • Unitronics VFD UMI Short Current Ratings and recommended protection devices
  • Unitronics VFDs B1 series Dimensions
  • Unitronics VFDs B5 series Dimensions
  • Filter installation and dimensions in Inverter
  • Connecting multiple motors to a single VFD
  • Running VFD frequency via Modbus and control via Terminal.
  • UMI-B1- STO Functional Safety Data
  • Auto start for VFD
  • short circuit current rating
