UniDDE and RS485
Mar-1st, 2020 12:51
If you wish to connect several PLCs in RS485 to UniDDE it is required to change the UniDDE settings as follows:
1. Close UniDDE
2.Open the file “UniDDE.ini” from C:\Program Files\Unitronics\Unitronics DDE Server (if the file is not located in this path please perform windows search for UniDDE.ini)
3. Add the parameter ConnectOnce=0 and save the file.
4. Run UniDDE
2 out of 6 found this helpful
