Load config INI files -Tips
Ori Ziv
Dec-31st, 2023 12:26
When using the Load config INI files ladder element there are few small tips need to remember in order to make  it work:
1) File name without any spaces: for example Change_1.
2) When open file save it on Unix(LF) format:
3) Example for Correct path to SD/DOK :
/UserLogs/Txt/INI/
4) Every beginning of the INI file need to start with [Version=100] LF.
