Installing older Unilogic versions on PC that has a newer Unilogic version
Hananel Vanunu
Dec-30th, 2024 8:43
In Order to install older Unilogic version on a PC that has newer version without the need to delete the new versionâ–ş
For example, you have 1.39.103 on your PC and you like to install 1.38.XX
1. End task of Unilogic Notifier from "Task Manager"
2. Rename the Unilogic folder C:\Program Files (x86)\Unitronics/Unilogic to Unilogic_1.39.103.0
3. Install Unilogic 1.38.XX
3 out of 10 found this helpful
