• Help Center
  • Submit ticket
  • Login
  • Unitronics website
    • English
    • Russian
    • English
    • Russian
  1. Home
  2. Help Center
  3. Unitronics VFDs
  4. Unitronics UMI Workshop
  1. Home
  2. Help Center
  3. Unitronics VFDs
DL
Daniel Logee
Apr-23rd, 2024 13:45
Attached is the setup file for Unitronics UMI workshopâ–ş https://downloads.unitronicsplc.com/Sites/plc/Technical_Library/VFD/UMI%20Workshop%20Setup%20V2.5.1.exe
3 out of 7 found this helpful
 Unitronics VFDs
  • Unitronics UMI Workshop
  • VisiLogic and VFD
  • UMI (Unitronics VFD) Regenerative
  • UMI (Unitronics VFD) Heat Dissipation
  • Cable length between VFD and motor
  • VFD - Configuring 2 frequency sources
  • UMI Braking Resistor Calculation
  • VFD Keypad Password
  • VFD - Stop VFD when communication lost with PLC
  • Unitronics VFD Quick Start Guide
  • Unitronics Motion Inverter cable gauge and required Torque for Terminals
  • Unitronics VFD UMI Short Current Ratings and recommended protection devices
  • Unitronics VFDs B1 series Dimensions
  • Unitronics VFDs B5 series Dimensions
  • VFD-Multi-set speed
  • Filter installation and dimensions in Inverter
  • Connecting multiple motors to a single VFD
  • Running VFD frequency via Modbus and control via Terminal.
  • UMI-B1- STO Functional Safety Data
  • Auto start for VFD
  • short circuit current rating
  • UMI VFD Integration on BACNET IP network
