Unitronics VFDs B5 series Dimensions
Jan-8th, 2019 10:28
Wall installation of UMI-B5 3PH 220V 1.5~15kW and 3PH 460V 1.5~30kW inverters
Wall installation of UMI-B5 3PH 220V 18.5~55kW and 3PH 460V 37~110kW inverters
Wall installation dimensions of UMI-B5 3PH 220V 1.5~55kW (unit: mm)
Wall installation dimensions of UMI-B5 3PH 460V 1.5~110kW (unit: mm)
UMI-B5 Flange installation
Flange installation of UMI-B5 3PH 220V 1.5~15kW and 3PH 460V 1.5~30kW inverters
Flange installation of UMI-B5 3PH 220V 18.5~55kW and 3PH 460V 37~110kW inverters
Flange installation dimensions of UMI-B5 3PH 220V 1.5~55kW (unit: mm)
Flange installation dimensions of UMI-B5 3PH 460V 1.5~110kW (unit: mm)
1 out of 1 found this helpful
