UniStream MODBUS Change Remote Slave ID or IP
Jan-18th, 2018 12:50
If you wish to change to the Remote Slave ID or Slave IP directly from the HMI (without downloading application) follow the below steps:
  1. Go to UniApps
  2. Select Network Tab and then MODBUS:
3. Select Ethernet Master or Serial master. Then press on the slave ID or IP that you wish to change:
4. Virtual keypad will appear - change to the required ID or IP and press on Ok,
Now UniStream as MODBUS master will connect to the required ID or IP.
1 out of 2 found this helpful
