Adding TU24 model to Visilogic Snap-in I/O
Yaron Cypis
Apr-11th, 2022 9:06
If TU24 model is not part of VisiLogic and you can add the I/O in HW configuration as below:
  • Close VisiLogic
  • In C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\HW Cfg\Elements List….you will find a file called ElementsList.ini
  • Enter the file and add "V350-35-TU24" to V350 list.
  • Save
  • Open VisiLogic and check again
For example:
2 out of 5 found this helpful
