The CPU IP is used for communicating using raw protocol (TCP TX & TCP RX utilities). For example, a barcode scanner connected to UniStream via Ethernet.
The Panel IP is generally used for downloading applications, viewing via VNC and online Test mode, and sending SMS or email.
