UniStream can perform as SQL Client and can connect SQL databases MS SQL server and MySQL.
You can:
- Access SQL database via IP address/hostname and instance name/port number.
- Build SQL Queries and execute them via Ladder functions.
- Connect Data Tables to SQL databases and transfer data via Ladder functions.
Attached are SQL Client example and installation & troubleshooting document.
6 out of 9 found this helpful
