Connecting UniStream to UniCloud - Generic Error
Mar-4th, 2021 9:12
In case you try to load certificate or Add Asset from Uniapps and get Generic Error,
do following steps:
1.Go to Uniapps>>Ethernet>>Network>>Ping
2. Send Ping to “dns.google”
Success:
Fail:
If ping to dns.google fail -PLC is not connected to internet or Panel IP setting is incorrect. Please check Panel IP settings:
1.IP, Subnet Mask, and Gateway
2.Check DNS
After set the IP setting ,try ping dns.google again, if success continue process and try load certificate or Add asset again.
If ping to dns.google success and still getting Generic error it may be that some ports are not open in your network.
Please try the following in order to check if ports 8883 and 443 are open:
On windows, open CMD and perform those two telnet commands:
1. telnet amiad8p4au6x2-ats.iot.us-east-1.amazonaws.com 8883
2. telnet sra.unitronics.io 443
Copy and Paste one command row each time to CMD window as shown below and click Enter:
Empty black screen - Success
Fail:
If one of Telnet commands failed it means that this port is not open, check with your IT department, and after open the ports go to Uniapps and complete the process
Very important that IT have to make sure there is a permition to the next site►
http://a3env6nv24qo0x-ats.iot.eu-west-1.amazonaws.com/
If two Telnet commands succeed, AWS site is permitted and still gets Generic Error please contact [email protected].
2 out of 5 found this helpful
