Why there are red cross images during Remote Access / Remote operation connection?
Reuven Mozes
Nov-8th, 2017 8:38
The red cross images may appears due to wrong/missing data. A URC file should solve the problem.
Solution 1
In Remote Operator - go to Cache file menu>Create Cache file (*.urc)..
Then Click on RUN.
Solution 2
In VisiLogic – go to project menu>create project file ….> and choose HMI Display tab to create *.urc file Now you can import the created *.urc file in Remote Operator under Cache file menu>Import Cache file
3 out of 8 found this helpful
