How many communication sessions can I open at the same time using Ethernet?
Nov-8th, 2017 8:55
Unitronics Ethernet card offers 4 sockets.
That means you will be able to communicate with 4 devices at the same time.
Each one of the sockets has its own default settings:
The V700 has a build in Ethernet card with 8 sockets.
That means that when using the V700 you will be able to communicate with 4 devices at the same time.
Each one of the sockets of the V700 has its own default settings:
You can configure each one of the sockets to your preferred settings using Socket Init. (TCP[master or slave],UDP,HTTP,SNMP and more).
4 out of 8 found this helpful
