UniLogics Minimum System Requirements
Nov-6th, 2017 14:35
Minimum System Requirements for UniLogics
  • 1.6 GHz or faster processor
  • 1 GB of RAM
  • 10 GB of available hard disk space
  • 5400 RPM hard drive
  • DirectX 9-capable video card running at 1024 x 768 or higher display resolution
  • 32-bit colors
Minimum requirements: Windows XP (SP3) and above. Recommended requirements: Vista (SP2) and above. Note that all Windows versions must be installed with the latest service patches released by Microsoft. Both x86/x64 systems are supported.
Notes: -Windows XP: the UniLogic installation will also include SQL 2008 R2 Express. -The UniLogic installation files for higher versions of Windows do not require SQL 2008 R2 Express.
4 out of 7 found this helpful
