UniLogic is stuck on Splash screen loading components
Nov-13th, 2017 8:07
If you have issue when running UniLogic and it is stuck on the splash screen loading components, please try the following:
Download the "UniLogic Diagnostics.rar" from the next link:
https://unitronicsplc.com/Download/UniLogicFixLoadingComponents/UniLogic_Diagnostics.rar
Then follow the below steps :
·         Close UniLogic
·         Reboot your PC
·         Unzip the downloaded file and copy all files to C:\Program Files (x86)\Unitronics\UniLogic
·         Run the file "UniLogic Diagnostics.exe"
·         Click on the "Diagnose" Button
·         If you will get any "x" mark, click on the "Fix" button
In case the issue is not solved please contact [email protected] or open a ticket in support.unitronics.com
8 out of 16 found this helpful
