Is it possible to use SMS and GPRS at the same time?
Nov-8th, 2017 9:42
SMS and GPRS cannot work at the same time. There is no option to send SMS while the GPRS is connected. You need to first disconnect the GPRS call (You can still stay registered) and then you need to activate the SMS config to be able to send SMS messages.
8 out of 11 found this helpful
