UniStream USB driver manual install
Apr-23rd, 2020 13:50
Manually Installing Driver, Windows 7/8/10
After you install UniLogic, connect your UniStream to your PC; and then open Device Manager.
The connected UniStream will appear as a USB Serial Device; right-click it and select Update Driver Software.
Select Browse my computer software; then click Browse.
Click Have Disk, and then navigate to the driver location, typically
C:\ProgramData\Unitronics\UnLogic\Drivers
and then click Open..
The correct driver should now appear under Model, click next to install it. If Installation is successful, Windows displays a Success message.
Check Device Manager; the driver should now be listed under Network adapters.
2 out of 17 found this helpful
