This list details every case of CPU ERROR in UNISTREAM controllers according to the code number:
This list details every case of CPU Error in Unistream controllers according to the code number:
CPU Error codes:
case 0: OnBoardIOconfig.cfg file is missing
case 1: ActiveCfg.exp file is missing
case 2: idx.exp file is missing
case 3: cfg.exp file is missing
case 6: CPU configuration file is missing
case 4: On Board Io FPGA Error
case 5: On-Board-IO initialization failed / On-Board-IO was not identified / On-Board-IO mismatch
case 7: CPU alive, but did not send initial keep alive
case 8: No response from CPU to AC (as if CPU is dead)
case 9: CPU have an SPI problem (failed reading the On-Board-IO model type)
