Theoretically, we support all types of standard SD and SDHC cards – normal size (V560/V570) and Micro SD (V130/350/1040/1210). Basically the SD card needs to have the option to be formatted as FAT32 from Windows..
We recomend the following specifications:
SD High Capacity (SDHC™) card is an SD™ memory card based on the SDA 2.0 specification.
• SDHC capacities range from 4GB to 32GB
• Speed class: Class 10
• Format: FAT32 - we recommend using the HPUSBDisk utility to format the SD card
