Format decimal precision for data table values and for export
Yaron Cypis
Apr-18th, 2022 13:47
1. Formatting decimal precision (for real/float type - how many numbers after the decimal point) to a column in Data Table:
     a. Open the data table in Unilogic, Right-click the required column to format, select Format from the menu. Set the required decimal precision for this column.
2. When Saving / Storing data table on SD card, using Store DTI as file FB:
    a. On parameter F (file type), select 5 - Formatted CSV. This will keep the column format when the CSV file is created.
1 out of 1 found this helpful
