At the end of UniLogic installation comes a text message that says that the PC does not have an installed version of UniLogic.
Nov-8th, 2017 12:36
Problem:
At the end of the installation comes a text message that says that the PC does not have an installed version of UniLogic.
Solution:
  • Uninstall UniLogic
  • Using the attached MsiZap Download the attached file named "MsiZap.zip"
    Unzip it and copy the "MSIZap.exe" file to C: \ drive
      • Run the command line ("cmd") as administrator
      • Type the command "cd \" to get to the root directory C:\
      • Copy/paste and run the following command: "msizap T {83C5EAE0-FB24-4ACD-848A-9286B0DC30C1}"
      • Copy/paste and run the following command: "msizap TWA! {83C5EAE0-FB24-4ACD-848A-9286B0DC30C1}"
      • Install UniLogic
    • Reboot the PC.
