What brand of SD cards can UniStream PLCs support? What is the SD maximum size? Does it support SDHC?
Nov-8th, 2017 9:57
Theoretically, we support all types of standard SD and SDHC cards – normal size (V560/V570) and Micro SD (V130/350/1040/1210). Basically the SD card needs to have the option to be formatted as FAT32 from Windows..
We recomend the following specifications:
SD High Capacity (SDHC™) card is an SD™ memory card based on the SDA 2.0 specification.
•             SDHC capacities range from 4GB to 32GB
•             Speed class: Class 10
•             Format: FAT32  -  we recommend using the HPUSBDisk  utility to format the SD card
11 out of 14 found this helpful
