Possibility to work with more than one U90 ladder application open at a time
Nov-20th, 2017 8:46
It is not possible work with more than one application open at a time. If you try to open a new or existing project, the project currently open project will close. If you have unsaved changes, you will be prompted to save them before the project closes.
