JAZZ PLC's can communication and programmed via with the following communication accessories:
| COM KIT Model | Adapter | Cable |
| JZ-PRG (JZ10 & JZ20 Series) | MJ10-22-CS10 (Can be used with USB to Serial converter) | Programming 6-wire cable,RJ11 MJ20-CB200 |
| JZ-RS4 (JZ10 & JZ20 Series) | MJ10-22-CS25 (Can be used with USB to Serial converter) | CABLE,COMMUNIC,RJ11,4W,GRY |
| Mini-USB Port (Build-in on JZ20 Only) | None | Standard USB to min-USB cable |
Also please see below the default communication setting for JAZZ PLC's.
