Here are some cameras that works with UniStream:
As there are many IP Camera manufacturers, Each manufacturer has its own hardware and firmware so the setting can be different between models.
We can suggest to pay attention to the next parameters when setting a camera:
· RTSP protocol support
· Video Compression: H.264
· Video Resolution and FPS (Frames per second):
NTSC | ||
Resolution | Size | Max. FPS |
QVGA | 320x240 | 30 |
VGA | 640x480 | 30 |
Full D1 | 720x480 | 30 |
SVGA | 800x600 | 30 |
HD | 1280x720 | 30 |
Stream video from a camera via the RTSP Protocol:
After placing the widget on the display, select the Source Type; the Properties change to reflect your choice:
Properties - RTSP Streaming | |
Source IP |
These are the camera's settings. |
Source Unique Name | |
Source Password |
If a password has been assigned to the camera, you must supply it. |
Source Port |
The default port for RSTP is 554. |
Show Video Controls |
When this is checked, the video player displays controls that enable the user to start, stop, and adjust the video volume. |
Start Volume |
Move the slider to set the volume level when the file is opened. |
Properties - RTSP URL | |
Video URL |
Enter the parameters according to your requirements. |
Start Volume |
We hope it helps.
