Submit ticket
Login
Unitronics website
English
Russian
English
Russian
Home
UniStream & UniLogic Communication FAQ
How many Ethernet connections can I have connected to a UniStream at one time?
Home
EM
Nov-7th, 2017 12:07
Since UniStream is run by Linux, sockets are virtual; many dozens of virtual sockets are available
Is UniStream EtherNet/IP™ compliant?
UniStream and USB serial device
Can the two Ethernet ports on the Panel act as a switch? (Bridging)
What is the difference between the CPU and the Panel IP address?
How do I remotely access UniStream via VNC viewer?
What communications ports does the PLC have and what protocols are supported?
Where and how many COM modules can I connect to a single UniStream?
What modems are supported by the UniStream PLC?
How do I set up a modem, and what hardware will I need?
Does the UniStream have Web Server capabilities?
Does the UniStream support SSL encryption for email, such as Gmail?
If the UniStream memory is dynamically allocated –lexical tags- how do I assign an address to the tags I wish to read/write using MODBUS communications?
What type of USB device can be connected to the USB host port of the UniStream?
