Yes, UniStream can act as a Web Server. Users can access Web pages hosted by UniStream using any web browser. You design web pages using UniLogic’s built-in Web Page Editor. No HTML coding required–you simply drag&drop elements and widgets, similar to the HMI Displays Editor.
You can also create different user accounts and multi-level password settings, and apply them to individual web pages.
Additional information can be found within the UniLogic Help file under Communications/ Web Server.
Configuring the Web Server
Please note that the Panel IP address is the one used by the web server
Security
Use security to require users to enter a password before accessing a web page.
Further notes:
1. Unistream products DO NOT use Log4J library.
2. Unistream Web Server is NodeJS based, not Apache.
