Run Unitronics software with no Administrator rights - as a regular user
Alex Karpov
Oct-5th, 2026 11:50
Dear Customer,
How to run Unitronics software as regular user.
1. The simplest and safest method is not to modify the Unitronics executable.
Tell Windows to start that specific program with the current user’s permissions using `RunAsInvoker`.
2. One-time test:
2.1. Open a normal Command Prompt, not Administrator, and run commands:
set "__COMPAT_LAYER=RunAsInvoker"
start "" "C:\Program Files (x86)\Unitronics\Unitronics U90 Ladder\U90Ladder.exe"
*Replace the path if necessary. Recommended to prepare string in text editor.
If the program opens and works correctly without a UAC prompt, make the setting permanent.
3. Permanent setting for one executable:
3.1. Run following command in a normal Command Prompt:
reg add "HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers" /v "C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\VisiLogic.exe" /t REG_SZ /d "RunAsInvoker" /f
*This affects only the current Windows user and does not require administrator rights.
4. To undo it, run command:
reg delete "HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers" /v "C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\VisiLogic.exe" /f
5. Important remarks:
5.1. Application MUST be installed As Administrator. Than it will run under user account.
5.2. If you have trouble - ask IT for assistance.
6. Any Unitronics program can be run this way.
Best regards.
Rate this article if you find it useful.
1 out of 1 found this helpful
