Remote IO - URD-0200E
Feb-2nd, 2020 14:02
Wiring Encoder:
Changing Configuration:
Please note that when you change the configuration of the 0200E , you must reset the controller. You get a message box when you change the configuration:
Performing Download All will execute reset as well.
Please note that you can also change the counter mode while the PLC is running using the outputs array – just set the counters mode according to the bitmap captured also from spec:
2 out of 6 found this helpful
