LoadCell Remote IO
Jun-9th, 2020 9:10
URB Loadcell/Strain-gauge I/O Module
These I/O modules enable you to integrate a loadcell or strain-gauge in your control application.
Attached are Examples for Vision and UniStream controllers.
To calculate the weight in user units you can use this formula ((A * 15.0 * C )/(D * B))*E.
Parameters A and B relate to the Unitronics I/O module's inputs.
Parameters C and D relate to the specifications of the Loadcell /Strain-gauge device you connect to the Unitronics' I/O module.
Parameter E, Scale Factor, can be used to fine tune measured results if required by using known weight, and according to calculated result, calculating the required offset percentage.
3 out of 6 found this helpful
