How to solve missing object on ladder elements (Contact & Coil)
Reuven Mozes
Nov-13th, 2017 8:06
Most likely it is PC issue (Resolution, monitor, Windows setting…etc) or some missing fonts.
Please close all programs.
Perform Windows update.
Check the text size is set to the default setting: Control Panel>Display.
If the setting are ok, please see more suggestions below.
Try to install the attached font and let us know if it helps.
If you can't use or see the attached font, please try to get and install the following font style:
  • Miriam Fixed
  • Microsoft Sans Serif
1 out of 1 found this helpful
