You use Actions to program event-driven events. There are two classes of Actions:
Project-level Actions enable you to use events to drive actions such as Load Screen, or to play Sounds.
To create an action:
Please Note
If the Action requires you to select an entity, such as a screen or sound file, make your selection in the Properties window.
HMI element Actions enables a single Touch Element to trigger multiple events. Multiple bits can be linked to one element, triggering Load screen, set, reset, and toggle bits, and more.
Note:The following elements do not have the Action Property:
Select the Action, Operand or Screen, and the action Trigger
