VisiLogic Cannot Access Network Drives
Reuven Mozes
Jul-16th, 2018 7:11
Symptom - After you turn on User Account Control (UAC) in Windows, VisiLogic may not be able to access some network locations.
This problem may also occur when you use the command prompt to access a network location.
Cause - This problem occurs because UAC treats members of the Administrators group as standard users. Therefore, network shares that are mapped by logon scripts are shared with the standard user access token instead of with the full administrator access token.
Solution:
*** Important ***
This section contains steps that modify the registry. Incorrectly editing the registry may severely damage your system or make your system unsafe. Before making changes to the registry, you should back up any data on the computer. For more information about how to back up and restore the registry, see article 322756 in the Microsoft Knowledge Base (http://go.microsoft.com/fwlink/?LinkID=133378).
To work around this problem, configure the EnableLinkedConnections registry value. This value enables Windows Vista and Windows 7 to share network connections between the filtered access token and the full administrator access token for a member of the Administrators group. After you configure this registry value, LSA checks whether there is another access token that is associated with the current user session if a network resource is mapped to an access token. If LSA determines that there is a linked access token, it adds the network share to the linked location.
To configure the EnableLinkedConnections registry value
  1. Click Start, type regedit in the Start programs and files box, and then press ENTER.
  2. Locate and then right-click the registry subkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System.
  3. Point to New, and then click DWORD Value.
  4. Type EnableLinkedConnections, and then press ENTER.
  5. Right-click EnableLinkedConnections, and then click Modify.
  6. In the Value data box, type 1, and then click OK.
  7. Exit Registry Editor, and then restart the computer.
Thank you.
6 out of 9 found this helpful
