Yes, it is possible.
Different controller models offer high-speed counter functions of the following types:
Selecting the shaft encoder function enables the counter to count both up (-3, -2, -1, 0, 1, 2, 3, …) and down (3, 2, 1, 0, -1, -2,-3 …). Note that the input requires you to use pnp-type shaft encoders.
If you select the high-speed counter function that does not include Reset, note that you must reset it within your Ladder program. This type of counter only counts up.
If you select the high-speed counter function with reset, the counter is capable of counting up within the positive range, 0-32767. This function uses the next-to-last input as a counter reset. Since the reset is done via the hardware, the reset is immediate and independent of the program scan.
Some of the sample programs installed together with U90 Ladder include high-speed counters of different types.
Please note that when you select High-Speed Counter with Reset, the controller uses an additional input for reset; shaft encoders also require the use of two inputs.
You can read more information on High speed I/O on U90 ladder help file under
Home > Hardware Configuration > High-Speed Counters, Shaft Encoders, Frequency Measurer
