How to use a serial connection for programming Unitronics PLC
Nahum Stern
Dec-26th, 2018 10:57
Before you try to communicate with PLC you should check you have the following cable & adaptor:
1. Male RJ11 Type connector.
2. A female D-Type MJ10-22CS25.
You can use USB to Serial adaptor:
*Some PLCs need to add a communication module to be able connecting this method.
Connection have to be implemented as following:
Hope that this information helped you.
14 out of 20 found this helpful
