How can I export the PLC data tables to Excel?
Nov-8th, 2017 9:47
You have 2 ways to accomplish this task manually and automatic:
  1. Manually – You can directly export the data to Excel from VisiLogic or Remote Access:
Open the Data Tables window.
While you are connected to the PLC –
Click on the icon Read/Write Tables and then select the table you wish to read and
click on Read Tables button.
After all the data is read – click on the row column to select all cells and then on the icon export cells to Excel:
2. Automatically – Using DataXport software which you can download from Unitronics web site.
Using this software you will be able to retrieve the data table or even regions of operands from the PLC automatically according to a schedule that you will determine in the DataXport project and export it automatically to Excel.
10 out of 11 found this helpful
 Vision & Samba Logic and application FAQ
