When you create an M90 network, you must assign a Unit ID number to each controller. A Unit ID number is unique. It must be used only once within a network.
You use this number for two purposes:
To set a Unit ID number:
Displaying the Unit ID Tool Bar
To download via an M90 bridge to a networked M90, you must select the unique ID of the networked M90. When you enter '0' as the Unit ID number, you communicate directly with the M90 that you are using as a bridge to the network.
