Yes, you can Import/Export applications.
To do so, navigate in UniApps to the Upgrades menu, then select the User Application Upgrade tab.
You can also install USB flash drive with the application, and import it into UniStream via UniLogic. This is done by opening the PLC tab on the ribbon and selecting Export project to a USB storage device, located on the Download menu.
Please note:
Only one project can be saved to the USB flash drive at a time.
This tool is not meant to export the application to be read by the UniLogic PC.
