In case that the Firmware need to updated when Local/Remote update will not help, follow the next procedure:
- Copy the Bin version to another FAT32 formatted flash drive (UniLogic > UniStream Management > Firmware Manager >Copy to DOK)
- When the copy process is done, browse to the flash drive > Open the Unistream_Files folder.
- Copy the attached file or create a new file without it extension named "force_UniStream_update_amb" (Attached) to the Unistream_Files folder.
- Unplug the flash drive from your PC and plug it to the "failed" UniStream Panel > USB Host
- Reboot the UniStream Panel
- The Upgrade process should start automatically.
At the end of Upgrade process, your DOK will contain a file that lists all files exist in the PLC: ..Unistream_Files\ current_list_files_sd_card.txt .
Send this file to us for further inspection and having the information about the problematic unit.
8 out of 18 found this helpful
