​Getting GPS data from Router (USC-ST-B8) to Vision PLC
Sep-2nd, 2020 6:09
Getting GPS data from Router (USC-ST-B8) to Vision PLC by MODBUS TCP. (Example attached).
First enable the GPS via the services menu --> GPS:
Then enable the MODBUS TCP Slave:
Now the Vision controller can be MODBUS TCP Master and read the data from the below registers:
5 out of 8 found this helpful
