• Help Center
  • Submit ticket
  • Login
  • Unitronics website
    • English
    • Russian
    • English
    • Russian
  1. Home
  2. Help Center
  3. UniStream & UniLogic Communication FAQ
  4. What modems are supported by the UniStream PLC?
  1. Home
  2. Help Center
EM
Nov-7th, 2017 12:11
The modems supported by the UniStream PLC are:
  • Enfora GSM1308-50
  • Cinterion BGS2T -2G
  • Cinterion EHS6T -3G-
Take in mind that every day more and more providers are closing there 2G network.
We recommend using only the Cinterion EHS6T, which is currently the only modem we provide.
6 out of 11 found this helpful
  • Is UniStream EtherNet/IP™ compliant?
  • UniStream and USB serial device
  • Can the two Ethernet ports on the Panel act as a switch? (Bridging)
  • What is the difference between the CPU and the Panel IP address?
  • How do I remotely access UniStream via VNC viewer?
  • What communications ports does the PLC have and what protocols are supported?
  • How many Ethernet connections can I have connected to a UniStream at one time?
  • Where and how many COM modules can I connect to a single UniStream?
  • What modems are supported by the UniStream PLC?
  • How do I set up a modem, and what hardware will I need?
  • Does the UniStream have Web Server capabilities?
  • Does the UniStream support SSL encryption for email, such as Gmail?
  • If the UniStream memory is dynamically allocated –lexical tags- how do I assign an address to the tags I wish to read/write using MODBUS communications?
  • What type of USB device can be connected to the USB host port of the UniStream?
