What is the difference between global and local tags?
Nov-8th, 2017 8:04
Global tags can be created and used throughout the application. You can set them to retain values. Local tags are created within a specific ladder function and are only available in this function, which makes them very handy for use in UDFBs. Local tags are stored in local memory, which increases processing speed. These tags cannot be retained, viewed online, or used in HMI applications.
4 out of 7 found this helpful
