What can cause the loss of TAGS values on power-up?
Nov-8th, 2017 8:03
There are two possible causes:
1. If the tag is not marked as a retained value it will not keep its value after power-up.
 2. No battery backup. The reason is typically a weak or missing battery. In UniStream, the indication is when in System Struct General>Battery Low=1.
3 out of 6 found this helpful
