What brand of SD cards can vision enhanced PLCs support? What is the SD maximum size? Does it support SDHC?
Nov-8th, 2017 9:55
Theoretically, we support all types of standard SD and SDHC cards – normal size (V560/V570) and Micro SD (V130/350/1040/1210). Basically the SD card needs to have the option to be formatted as FAT32 from Windows..
We recomend the following specifications:
SD High Capacity (SDHC™) card is an SD™ memory card based on the SDA 2.0 specification.
             SDHC capacities range from 4GB to 32GB
             Speed class: Class 10
             Format: FAT32  -  recomendamos usar la utilidad HPUSBDisk para formatear la SD.
10 out of 13 found this helpful
