SD Formatter
Guy Sela
Nov-25th, 2020 9:04
Download the next formatter and format your DOK/SD
http://unitronicsplc.com/Download/Help_desk_Article_links/SD_Format.zip
Make sure the size the PC detect is the actual size of the storage:
If the size does not the right one, use the "Option" and use the "Full" format to restore the actual size of the  SD/DOK.
3 out of 7 found this helpful
