How can I create a clone file from VisiLogic to be loaded via the SD card?
Nov-8th, 2017 10:06
It is necessary to format the SD card using Unitronics SD Card Suite.
  1. These tools are available for download free of charge from our website:
  2. www.unitronics.com à support à downloads à Unitronics SD Card Suite: free download
  3. The SD Card Formatter is an available option under the “Tools” program of the suite.
  4. Make sure to select the “Format Drive using Windows” option first.
  5. After, uncheck the box and format again.
    Prepare File in VisiLogic:
  1. First it is necessary to prepare a project file (*.vXX) for the SD card.
  2. Place the newly created file in the “USER_APP” folder of the SD Card.
    Load via Information Mode:
  1. With the SD Card inserted, hold down the touch screen for a few seconds until Info Mode opens.
  2. Enter the Info Mode password (default : 1111)
  3. Select “SD”
  4. Select “Application”
  5. Select “Upload to PLC”
  6. Select previously created file to install
    NOTE: (SD operations can also be programmed into the application’s ladder logic now with latest VisiLogic version)
10 out of 17 found this helpful
