What types of media files are supported?
Nov-7th, 2017 12:50
UniStream PLC support reproduction of media files.
The following media is supported on UniStream PLCs:
  1. Images:  .bmp, .gif, .jpg,, .png and animated gif. If the dimensions of the picture exceed the resolution of the panel (800×600 for the 10.4” panel, 800×480 for the 7” panel), the image is resized to the panel dimensions
  2. Audio: The UniStream can play sound files – You can use mp3 and .wav.
  3. Video: The UniStream can play Video files, .avi and .mp4.
  4. PDF – The UniStream can display PDF files.
Please note that when a file data size is bigger than 4MB the media file will be downloaded to the external SD card.
3 out of 3 found this helpful
